Exchange 2010 Federation DNS Record
Hi I’m setting up Federation for Exchange 2010 and it requires creating a TXT record in DNS. Zonerunner is giving me an error though that the record contains bad characters, and I suspect it’s the plus signs (+).
Here is the output from Exchange that I need to enter into the TXT field:
TE1lecm+qI9tiG0AdluNbzqgjpIuDkC56+gcjUBJbbf60vm8nivrYFuxg3F/HjeHriGO9EVdCa197d6kiggFSw==v
Also, here is the article on creating the record. Does anyone know how I can get this record created in ZoneRunner?
I’m able to create that TXT record by putting the text in double quotes, as noted in the GUI help:
“Specifies, for TXT records, a list of one or more text strings. You can use TXT records to specify any information you want; a common use is to specify a host machine’s location. Each text string must be enclosed in double quotation (”) marks, and can be no longer that 256 characters."
If I don’t, I get the bad characters error message. Are you able to add it using quotes?
Brilliant!
