Exchange 2010 and BigIP v11.1??
Does anyone have a successful setup with BigIP V11.1 and Exchange 2010 (with multiple front end CAS servers)? We have had alot of issues since setting it up. The main issue is authentication prompts that Outlook users get, and when a server is rebooted that a users Outlook is pointed to, instead of failing over to another server nicely they get a nice authentication prompt from within Outlook. I have had a ticket opened with F5 since Mid December and while they have worked hard to help figure this out, the issue is still occurring. There is also an issue of sometimes Outlook clients getting a “server not available” when loading Outlook. The only solution is to reboot the computer and then everything works fine. If a computer is manually pointed (via host file) to an Exchange server directly there are 0 issues, only when they go through the F5 do we get these problems.
I was wondering if someone had a similar setup that is working without issue so I could compare some settings and such to see if I can get this working.
Thank’s
Brent
I will be happy when they resolve this issue, since we have been making all types of changes internally trying to rule out F5 as the issue
Brent,
Did you configure the BIG-IP for Exchange using the built-in iApp template and the deployment guide? There are several post-config steps that need to be done, but I assume that F5 support walked you through those.
Are your users connecting via OutlookAnywhere, or MAPI?
thanks
Mike
Posted By mikeshimkus on 03/22/2012 08:10 AM
Brent,
thanks
Mike
Yes, we used the built in iApp template and the deployment guide. It is configured exactly like it should be according to it. F5 has spent alot of time troubleshooting the issue and have been helpful, i just thought it would be a good idea to throw the question out here as well with the large forum base to see if anyone else is having similar issues.
The users all connect using MAPI. It is very intermittent, but it seems most users get the authentication popup a couple times a week, Outlook not being able to connect to the Exchange server is even more random but I have even had it happen to me a few times. Again, none of this happens when the users point directly to the server.
Posted By Creighton on 03/22/2012 08:05 AM
So you have had issues as well? Care to elaborate? Any authentication prompts issues or Outlook not being able to communicate to your Exchange servers? I am just trying to see if they are similar to what I am experiencing.
Brent
Can you give me your F5 case number so I can have a look?
C1014424
Our Exchange 2010 infrastructure is staying on v10 for the time being. It was difficult enough to get working properly there, so I can’t imagine attempting to migrate to v11 yet.
My colleague and I are having a look at the case notes. About your OneConnect question-manually disabling OneConnect with an iRule was necessary at one point. However, I’ve been told that as long as you have a correctly configured NTLM profile attached to your combined https virtual server, you *should* not have to do this. I am testing with the same version you are running and this does seem to be true.
That being said, have you tried removing the OneConnect profile altogether from your virtual server, just to eliminate that as a possible cause here?
Yes, we have removed the oneconnect profiles, tcp profiles, http profiles, everything one by one trying to see what would fix it (nothing worked).
I am running a version of the Exchange 2010 iAPP that has not been released yet, and in the persist irule it contains the code to disable OneConnect, this code was not in previous versions.
when HTTP_RESPONSE {
if { [HTTP::header values WWW-Authenticate] contains “Negotiate” } {
ONECONNECT::detach disable
So should the above really not be there?
Everything is pretty much an out of the box setup as far as Exchange and the F5 VS goes, nothing fancy at all.
It should be said that we have other applications running on the F5 without issue, so whatever the problem is it definetley seems to be related to the Exchange iAPP.
I did not realize you had a copy of the unreleased iApp template from February 7. We have a newer version but, we’d still like to do some testing with it before we distribute.
I just got more info about the NTLM profile. In fact, it only supports the NTLM auth method, not Negotiate, so you do need to keep that statement in your iRule.
I am going to try to reproduce your issue in our environment. I’ll post here with any further questions or suggestions (might be tomorrow).
Yeah, the last engineer on the case gave it to me to try, it didnt fix any issues though.
Thanks for looking into it.
Brent,
I think I may have replicated the issue in my environment, at least the behavior seems similar. Under the properties of your combined Exchange 2010 https virtual server, can you set the fallback persistence profile to this:
EXCHANGE_2010_SP2_VS_source_address_persistence_profile
The default persistence profile should be cookie.
Let me know if that helps.
Mike
To clarify, the default persistence profile should be the cookie profile created by the iApp…
When i attempt to do that I get this error. ( I am trying this on the test VS i created first as to not affect production)
01070372:3: Persistence mode (Cookie) called out in rule (/Common/EXCHANGE_2010_SP2_VS_TEST.app/EXCHANGE_2010_SP2_VS_TEST_combined_vs_persist_iRule) requires a corresponding persistence profile for virtual server (/Common/EXCHANGE_2010_SP2_VS_TEST.app/EXCHANGE_2010_SP2_VS_TEST_combined_https).
For that virtual the default persistence profile should be EXCHANGE_2010_SP2_VS_TEST_cookie_persistence_profile
and the fallback persistence profile should be EXCHANGE_2010_SP2_VS_TEST_source_address_persistence_profile
You shouldn’t get that error unless you try to remove the cookie profile from the virtual server altogether.
ah, sorry. It was too early in the morning when i read your last post. I have set the FAILBACK to source_address_persistence_profile.
What do you expect this to fix, the authentication prompt issues?
Brent
What I found in testing is that Exchange wants the EWS connection to go to the same CAS server as the RPC connection. If they connected to different servers, I had authentication problems. The source persistence profile is set to “match across services”, which should send all connections from that IP to the same node (even if you’re using two different pools, it’ll work as long as the pool members are the same in both).
You can see which nodes you’re persisting to by logging into the BIG-IP, then typing:
tmsh
ltm
show persistence persist-records all-properties
This is our production environment (without the setting you told me to make and IP’s changed for security) would something like this below in the persistent record cause issues? Where the users is pointed to multiple servers? (172.10.x.156 and 172.10.x.164)
172.5.x.115 1 0 Source Address Affinity EXCHANGE_2010_SP2_VS_rpc EXCHANGE_2010_SP2_VS_rpc_pool 172.10.x.156:135 63 seconds
172.5.x.115 1 0 Source Address Affinity EXCHANGE_2010_SP2_VS_combined_https EXCHANGE_2010_SP2_VS_owa_pool 172.10.x.164:443 27 seconds
172.5.x.115 1 1 Source Address Affinity EXCHANGE_2010_SP2_VS_combined_https EXCHANGE_2010_SP2_VS_owa_pool 172.10.x.164:443 32 seconds
Check your inbox, I just PM’d you.
