Excessive amounts of Current Sessions
Hello
After running command ‘tmsh show ltm node raw MYNODE1’ I found the Current Sessions value to be huge:
Current Sessions - 18446744073709551512
This value has not changed in two days.
The number of current sessions to the pool is only in the hundreds so I don’t believe the above value is accurate:
tmsh show ltm pool raw MYPOOL1 … Current Sessions : 944 …
Is this a bug in 11.2?
I know how to check the current connections, but is there a way to view the current sessions?
Is there a command to clear the session counters?
Many Thanks,
It happens with 11.5.1 as well. I contacted support back with 11.2.1 and they said it was a known problem with no current workaround. The value seems to be accurate until some threshold and then it goes bonkers.
Thanks Pete!
I wonder if there is a SOL… reference.
There appears to be a fix for APM according to SOL17259, but no mention of LTM.
K86571182: Pool level current sessions statistics display an inaccurate value - myF5
