can anyone help with this..
its not working
my code
class noSSL {
myutil
util_forum
if { [matchclass [HTTP::uri] ends_with $::noSSL] } {
HTTP::redirect http://[HTTP:host][HTTP:uri]
error:
01070151:3: Rule [nsaonline.ch-non-https] error:
line 1: [undefined procedure: class] [class noSSL {
myutil
util_forum
line 8: [undefined procedure: HTTP:host] [HTTP:host]
line 8: [undefined procedure: HTTP:uri] [HTTP:uri]
Are you trying to define the class within the iRule itself? I don’t think that works. I’m pretty sure you have to declare the class separately (as a datagroup). Try that.
ahhh!.. found the datagroups
ok so i defined my datagroup,
and i still get :
01070151:3: Rule [nsaonline.ch-nonssl] error:
line 3: [undefined procedure: HTTP:host] [HTTP:host]
line 3: [undefined procedure: HTTP:uri] [HTTP:uri]
Try putting the URL in quotes:
HTTP::redirect "http://[HTTP:host][HTTP:uri]"
I’m not sure if it’s required (I forget the exact TCL rules about this stuff), but it’s the only thing I see that might be wrong.
same thing..
if { [matchclass [HTTP::uri] ends_with $::nonSSL-nsaonline.ch] } {
HTTP::redirect “http://[HTTP::host][HTTP:uri]”
still getting this error
I think I see it. You only have 1 ‘:’ where you need 2.
HTTP::redirect "http://[HTTP::host][HTTP::uri]"
SWEET that was it.. THANKS!!!
cant believe i didnt see that.
ok.. so ive come to this
http profile:
if { [HTTP::uri] ends_with “myjuiceplus” || [HTTP::uri] ends_with “juiceplus_forum” } {
HTTP::redirect http://[HTTP::host][HTTP::uri]
else {
HTTP::redirect https://[HTTP::host][HTTP::uri]
ssl profile:
and it kinda works.. when i hit the ssl page and navigate to the page that ends with myjuiceplus or juiceplus_forum, it forwards to http
but the page says
The page isn’t redirecting properly
any ideas??
got it..
needed to take out the
on the nonssl irule.
