Exceeded maximum memory assigned for XML/JSON processing
I keep getting “Exceeded maximum memory assigned for XML/JSON processing” during processing of XML payload on v11.2.1HF5. I increased total_xml_memory number of times, but it does not help. Looks like a memory leak.
Any suggestion ?
Raise a support case with F5 to have it diagnosed.
HOWTO ADJUST: 404 Page not found | BIG-IP Documentation VERIFY: mysql -p`perl -MPassCrypt -nle ‘print PassCrypt::decrypt_password($_)’ /var/db/mysqlpw` DCC -e “SELECT field_name,factory_value,current_value FROM INTERNAL_CONFIG_ITEMS WHERE field_name=‘total_xml_memory’;” UI equivalent: Security > Options > Application Security > Advanced Configuration > System Variables
