Evaluate String against data-group of IP data
Hello to all,
I have AKAMAI as a CDN provider in front of my F5 published services. I have configured a data-group of type “Address” and before AKAMAI, I checked if the client IP could be found in this data-group and allowed access towards a specific path:
"/uri_path*" {
pool server-pool
if { !([class match [IP::client_addr] equals dg_allowed_ips])} {
HTTP::respond 403 content ""
log local0. "tried to connect to ret from [IP::client_addr]"
Now after introducing AKAMAI, since the client IP is replaced by that of the connecting AKAMAI server, I needed to get the actual client IP using a custom header:
if { ([HTTP::header exists "True-Client-IP"]) and ([HTTP::header "True-Client-IP"] != "") } {
set True_Client_IP [HTTP::header "True-Client-IP"]
set True_Client_IP [IP::client_addr]
If I change the evaluation to use this new variable, it basically never matches since the variable is of type “string” whereas the data group contains IPs:
"/uri_path*" {
pool server-pool
if { !([class match $True_Client_IP equals dg_allowed_ips])} {
log local0. "tried to connect to ret from $True_Client_IP"
So the question becomes: can I evaluate a string over a an IP data-group? Can I somehow change the variable type to be IP?
Thank you all
Technically, [IP::client_addr] also returns a string. Are you getting any logic errors in the LTM log?
Try logging the value of True_Client_IP to see if maybe there’s some anomalous characters in the value.
log local0. "|${True_Client_IP}|"
No, I don’t get any errors in the logs. I’ve also inserted the extra logging, and it correctly includes the IP without any special characters.
What do the address values look like in your data group?
And what BIG-IP version?
I’ve tested this login on a 17.0 box and it appears to work fine.
