Error with "SOAP-ENV:Client Unknown method"
I met a error running with v11.2 while JDK downloaded with v11.X, the detailed error as below:
SOAP-ENV:Client Unknown method “{urn:iControl:ITCMSystem/SystemInfo}:get_product_info”
[root@dc1-bigip3:Active] LocalLB SOAP-ENV:Client Unknown method "{urn:iControl:ITCMSystem/SystemInfo}:get_product
https://devcentral.f5.com/wiki/iCon…loads.ashx
Version 11.x
iControl-11.1.0
Any hints?
BTW, Does latetst JDK installed on TMOS with path? I would like to find it out, thanks!
The “ITCM” in the namespace is for BIG-IP v4.x. I’ll need to update that page to link to the newer libraries. The client side libraries have moved from the SDK into separate downloads in the iControl Assembly labs project: DevCentral You should be able to find Java and .Net downloads for v11.2 (and below). Sorry for the mixup…
-Joe
