Error while deleting pool in LTM
I am getting error while trying to delete pool and node. This would be only used for next hop tracking to decide fail over condition.
01070265:3: The Pool (/Common/radio-ext-pool) cannot be deleted because it is in use by a monitor rule (1 /Common/custom_gateway_icmp 3 0 /Common/radio-ext-pool).
It seems pool is in use somewhere in HA configuration. Remove the mapping of the pool from that failover configuration and then try to delete the pool.
Hi Pratik Removed all relevant configuration from HA next hop tracking under failover groups. Also deleted the pool member from the pool along with the relevant monitor. Still I keep on getting the same error.
Open /config/bigip.conf and /config/bigip_base.conf file through WinSCP and search for your pool name, may be it is still mapped somewhere.
on the LTM command line, try
tmsh list ltm one-line | grep radio-ext-pool
or
tmsh list one-line | grep radio-ext-pool
those should also show you any other places in the config where that pool is referenced
