Greetings all
Having an issue with an SSL certificate which I’m trying to import into the BIG-IP LTM 2000S. The error appears as stated below:
01070712:3: Caught configuration exception (0), unable to validate certificate, invalid x509 file (/Common/WBCert.crt). - sys/validation/FileObject.cpp, line 5654.
Any help is greatly appreciated.
I suppose the first question is, is it a valid x509 certificate? Can you open it with OpenSSL?
openssl x509 -noout -text -in WBCert.crt
HI kevin, same problem here, as per your suugestion how i will check from openssl? OpenSSL will only happen if certificate is already there in system…? correct me if wrong
You can use OpenSSL from any Linux-based system.
This may be too obvious, but I did want to share that I had this same error once when I inadvertently tried to import the CSR file instead of the CER file…
Hi B_Stephen,
If your intention is how to use openssl for the same task from LTM, you can use open source Filezilla sftp client (you need to download that) or any other sftp client and connect to LTM (root@ltm_mgmt_ip_addr) and store it for e.g. in /var/tmp.
Then from LTM, you can use openssl command to view it.
e.g. I have a cert in PEM format called “abc-client2-cert.pem”.
[root@mks116:Active:Standalone] tmp openssl x509 -in /var/tmp/abc-client2-cert.pem -text -noout
Certificate:
Data:
Version: 3 (0x2)
Serial Number: 6 (0x6)
Signature Algorithm: sha256WithRSAEncryption
Issuer: CN=MKS-CA2, C=SG/emailAddress=mksaravtest@gmail.com
Validity
Not Before: Apr 1 16:38:39 2016 GMT
Not After : Apr 1 16:38:39 2017 GMT
Subject: CN=abc-client2, C=SG/emailAddress=mksaravtest@gmail.com
Subject Public Key Info:
Public Key Algorithm: rsaEncryption
Public-Key: (2048 bit)
Modulus:
00:ad:d2:da:b5:fa:fc:32:e1:5e:bf:cb:a7:c4:d9:
c3:80:71:b6:4b:09:03:d2:41:b1:e3:b9:eb:9d:c5:
92:95:5e:3b:67:1f:1b:7d:14:7f:37:85:5d:4a:d1:
3c:6d:ef:87:3f:81:96:46:8f:57:ab:a3:6a:81:8a:
47:0e:aa:16:ba:b2:93:8e:17:85:c6:3f:1a:61:7b:
2c:ea:a1:d8:8a:40:46:9d:bd:70:ff:62:78:67:5c:
fd:a7:fe:3e:e3:dd:3f:2f:5a:e7:c4:1a:05:2f:f7:
79:6a:75:91:ff:3c:d2:a7:d9:cd:e7:76:fb:35:22:
19:f9:7a:9d:ea:b3:b2:c2:e9:d4:95:97:c3:69:84:
eb:21:f6:dc:53:19:ab:a1:d7:db:37:6c:03:81:99:
1e:9c:b5:15:b5:20:2b:3c:cf:19:51:8a:88:be:9a:
f3:b9:97:e7:6c:85:ef:95:cf:a5:4b:c9:b0:83:91:
07:53:40:7e:22:a1:f4:31:89:22:09:b4:87:c9:1e:
b9:40:11:86:36:5a:69:11:71:c5:3d:99:a6:0e:34:
02:d6:a1:a6:b5:aa:9b:81:5b:4d:a9:28:64:e5:c4:
60:df:32:e8:52:a5:2a:c7:d1:e8:88:37:df:1e:8d:
91:36:f4:0f:35:01:83:ee:af:e1:b3:22:56:5e:37:
3f:3b
Exponent: 65537 (0x10001)
X509v3 extensions:
X509v3 Key Usage: critical
Digital Signature
X509v3 Extended Key Usage: critical
TLS Web Client Authentication
15:c0:75:69:00:58:7d:bb:b8:3b:35:b1:d8:26:29:9b:ae:df:
f9:8f:ad:cf:27:8c:1f:0e:bb:29:0f:c4:7a:c0:8b:4f:b6:b4:
a6:ea:64:74:89:4c:de:9e:3e:56:ea:a3:2f:7c:b0:3b:b2:4f:
4b:e0:51:6c:25:92:01:a1:fc:a3:73:22:88:7b:7e:ca:f9:f3:
ff:d4:16:91:eb:ad:a8:d9:e2:93:25:69:15:58:28:8a:0b:6c:
ab:8e:11:3a:b2:7c:47:aa:55:56:83:14:cc:61:03:61:c8:43:
81:6b:14:59:46:9e:8d:3f:e3:93:24:45:5d:48:7f:a9:03:1c:
43:e4:4c:3b:d0:e2:82:d2:02:41:33:bf:c6:f9:13:92:3f:15:
9b:58:cb:2a:13:8b:04:dd:a1:e3:02:72:b7:3e:e0:dc:42:ba:
c4:cb:2f:a9:e7:53:c3:bc:7a:dd:42:6d:2b:7d:48:69:99:22:
63:d5:f6:8c:62:f0:bd:40:6b:d1:3d:02:e9:79:7d:e1:d9:51:
a6:c8:af:c1:31:cd:4b:87:f2:2a:ef:8d:b6:b5:5b:42:c6:54:
24:f6:8d:66:45:44:cf:b1:91:1a:30:40:29:8c:10:03:37:f5:
62:80:bc:ab:99:4e:8a:42:c9:5a:02:70:c0:f8:57:70:04:c7:
92:34:fe:a7
If your cert is in DER format, then use:
openssl x509 -inform DER -in ./abc-client2-cert.der -text -noout
Alternatively you can install CYGWIN on Windows (to get a unix like environment) and install openssl in it. Then you can do all openssl stuff from Windows itself.
