Error msg in LTM logs
Afternoon all,
i’m getting the following error in my LTM log
http_process_state_prepend - Invalid action EV_EGRESS_DATA during ST_HTTP_PREPEND_HEADERS
This is the iRule i’m using, that is causing the error message
   if { [HTTP::uri] starts_with "/rweb" }{
   SSL::disable serverside
   pool Apache_DEV
Any thoughts?
Do you get the error on every request starting with /rweb?
Are you setting the pool to another pool in an else clause? If not, can you try this?
Aaron
Yes, only on requests for /rweb.
This is only development at the moment, so the else clause is just a HTTP::respond. There is no default pool either.
What version are you running? I tested on 9.2.4 with the following rule and didn’t see an error:
   if {[HTTP::uri] starts_with "/disable"}{
      log local0. "disabling server SSL"
      pool test_http_200_pool
      HTTP::redirect http://google.co.uk
      log local0. "redirecting"
This was on a VIP with no default pool and client/serverside SSL profiles added by default.
Aaron
