error in publishing sharepoint 2013 iapp with asm
i recently upgraded our staging environment to version 12.1.1. we are running a HA pair with ltm+asm+apm. At the moment, we cannot publish sharepoint 2013 iapps using the latest template, as it gives the following error message: "01071abb:3: Cannot create/modify published policy ‘/Common//_policy, try specifying a draft folder like /Common/Drafts…’
if i remove the option to publish with asm, it works. But we need asm, so this is a bit annoying. furthermore, an asm policy is created and in the list of active policies But it has no virtual server associated, and no partition where it is created, so we cannot deactivate them either.
does anyone have any ideas or thoughts around this?
Hi Kai, yes, the syntax changed in 12.1 because LTM policies need to be created as drafts before being published.
For now, I recommend getting the SharePoint 2016 v1.0.0rc1 template from the iApp templates package on downloads.f5.com: Page has moved
It’s in the release candidates folder. This is the same as the 2013 iApp, just rebranded. We’ll get this into the 2010/2013 iApp in the next release.
thanks
Mike
thanks for the answer! i uploaded the template you suggested, and published a service succesfully :slight_smile:
