Error Handling
Does the API consist of a list of error codes specific to the FirePass SSL VPN Client itself? Or will it simply return the standard HRESULT values when encountering runtime errors?
Windows HRESULT values are returned. These are documented in the SDK documentation for each method.
--JST
Thanks for the information! I will look them up in the SDK documentation.
