I have a Bigip LTM 6900 frozen and only can access via console.
when i try run the operatin system from the disk, appear “Error 22 :no such partition”.
I have decided reinstall the software from USB.
I have followed the steps to boot the unit using USB Mass Storage with the umdinstall.exe application in Windows . But when I insert the usb in the Bigip appliance and power on the unit appears the following error:
USB storage device found … General USB Flash Disk USB Device
IDE storage device found … IDE 0/Pri Master, SILICONSYSTEMS INC 8GB-
Embedded BIOS Debugger Invalid Opcode Trap
EAX = 00000000 CS:EIP = 0000:00007E01 EFL = 00000246 pl ZR .. na .. PE .. nc
EBX = 00000000 SS:ESP = 0000:0000FFFC EBP = 00000000 .. nt IOPL0 nv up EI ..
ECX = 0000FFFF DS:ESI = 0000:00000000 FS = 0000 .. .. id vp vi al vm rf
EDX = 00000080 ES:EDI = F000:0000DFB1 GS = 0000
0000:7E01 db FFh / “.” (255).v
EBDEBUG>
Somebody know this error?
Thanks.
