Hi.
We have faced a problem with an iRule.
This is the iRule:
Dec 10 13:42:10 tmm tmm[1729]: Rule regla_wap_mms_v1_pt_chatv4_data : Contenido ÂÀ À@Ohttp://213.229.187.118/chat/v4-c/chat.w.wml?sid=b5b2384d1&a=rl&c=62919849366003µhttp://motorola.handango.com/phoneconfig/E1000/Profile/E1000\_WITH\_BEARER.rdfÀ Dec 10 13:42:10 tmm tmm[1729]: 01220001:3: TCL error: regla_wap_mms_v1_pt_chatv4_data - Address in use (line 1) invoked from within “pool pool_WAP”
And the iRule:
when CLIENT_ACCEPTED {
set cliente [IP::client_addr]
if {[matchclass $cliente equals $::dg_wap]} {
pool POOL_WAP_v1_PT
if {[matchclass $cliente equals $::dg_mms]} {
pool POOL_MMS_v1_PT
when CLIENT_DATA {
set contenido [UDP::payload 500]
if {$contenido contains “213.229.187.118”} {
log local0. “Contenido $contenido”
pool pool_WAP
log local0. “Chat”
The traffic start being balanced to a pool regarding client IP, but for a specific kind of traffic, it must be balanced to a diferent pool.
The first part of the irule seems to work fine, but when second part (CLIENT_DATA), has to be applied, it crashes, and the error above is shown. Do you know what that error means???
I understand there is a problem when assigning to the pool pool_WAP. At that point, one connection has been established to one of the pools of ther CLIENT_ACCEPTED part, and it seems to crash when trying to assign same connection to another pool.
But, the thing is I am not very sure of that behaviour. I have done several tests with other protocols, assigning diferent pools to the connection in the same iRule, i have never seen that error, so i am not very sure of what it meant.
Have you ever seen that error???
Do you know what can be happening??
Thank you very much in advance.
BR
