Equivalent iRule in 4.x....
This iRule is for 9.x.
Can someone let me know the equivalent iRule in 4.x?
b rule http_inspect_uri_routehash_persist_rl
{ when HTTP_REQUEST
if { [set routehashvalue [findstr [HTTP::uri] “routehash=” 10 “&” ] ] }
persist uie $routehashvalue
log local0. “URI= $routehashvalue”
IIRC, there is no equivalent.
You could get close to the findstr by doing a simple contains check:
if (http_uri contains "routehash") {
and you could even extract the parameter value, but you can’t manipulate the persistence table in v4 iRules, so it would all be in vain.
