Hi, I have started recently working on APM. I would like to know what does EPSEC and OPSWAT actually do? How are they actually used in this module.
Thanks, Chandra
Thanks, Chandra
In APM you can configure policies based on client side check. OPSWAT is plugin APM uses to do the software check under the client side check.
Thank you!!
Thank you!!
