Ephemeral nodes goes in wrong partition
Hello everyone,
I’m trying to create a pool with auto-populated nodes. These pools & nodes are in dedicated partitions, that have its own routing domain.
The problem is that epheremal nodes are created in Common partitions, which contains no routes to realize monitoring checks, so my pool go red and become unusable.
Is there a way to create ephemeral nodes in the same partition than nodes they belong to ?
v12.1.3.6
which F5 version you are running?
Hi, 12.1.3.6
Ephemeral Nodes do not work with Route Domains before version 13 (think still some issues on v13) which is most likely your issue.
The following iRule can be used to fix this by performing dynamic DNS resolution, not sure if you can use this directly or use to build a solution for your requirements: Dynamic FQDN Node DNS Resolution based on URI with Route Domains and Caching iRule
