Problem this snippet solves:
Hi Folks,
the iRule below can be used to enforce individual APM Policy “In Progress Sessions Limits” per source IP address.
The iRule make use of
[class match]
to retrive custom settings for individual client IPs and then uses
[table]
to count and finally enforce the individual “In Progress Sessions Limits” for APM authentication.
Cheers, Kai
How to use this snippet:
- Tweak the provided data-group and RULE_INIT section as needed.
- Import the data-group and iRule to your device.
- Attach the iRule to your APM enabled Virtual Server.
- Open different APM authentication sessions (via InPrivate browsing) to see if the iRule is able to block further APM session creations if the counter is reached.
Code :
ltm data-group internal DG_APM_SESSION_LIMITS {
records {
1.1.1.1/32 {
data 50
2.2.2.0/24 {
data 100
type ip
when RULE_INIT {
set static::inprogress_session_limit 5
set static::access_policy_timeout 300
when ACCESS_SESSION_STARTED {
log local0.debug "Started"
if { [set SessionLimit [class lookup "[ACCESS::session data get "session.user.clientip"]" "DG_APM_SESSION_LIMITS"]] eq "" } then {
set SessionLimit $static::inprogress_session_limit
if { [table keys -count -subtable "APMSessions_[ACCESS::session data get "session.user.clientip"]"] > $SessionLimit } then {
ACCESS::respond 200 content "<h4 id="community-286633-toc-hId-1259126916">To many concurrent logon sessions from your IP address</h4>" noserver "Content-Type" "text/html"
ACCESS::session remove
log local0.debug "Login from client IP \"[ACCESS::session data get "session.user.clientip"]\" was blocked. Too many inprogress sessions..."
table add -subtable "APMSessions_[ACCESS::session data get "session.user.clientip"]" "[ACCESS::session data get "session.user.sessionid"]" 1 indefinite $static::access_policy_timeout
when ACCESS_POLICY_COMPLETED {
table delete -subtable "APMSessions_[ACCESS::session data get "session.user.clientip"]" "[ACCESS::session data get "session.user.sessionid"]"
Tested this on version:
12.0
