We’re about to leverage our LTM’s for a partnership, and need to know how to take unencrypted traffic and encrypt it.
Basically what we’re doing is:
-Traffic will come in from our partner via HTTPS. Big-IP will serve as the SSL termination point, convert the packets to HTTP, change the port number (to a pre-defined port, let’s say 4000) that the server is listening on, and forward them off to the servers (which cannot read or interpret HTTPS packets). This entails setting up a client SSL thing.
-The servers will then respond with HTTP traffic over, again let’s say port 4000 after they have processed the data, at which time the LTM will take the unecrypted data, re-encrypt it, and send it as HTTPS traffic via port 443 to our partner. This requires a server SSL configuration.
Now the twist:
-The servers will also need to proactively send HTTP traffic to our partner without first receiving a packet that the LTM has decrypted. We need the LTM to proactively encrypt that data that comes in as HTTP over…again, let’s say 4000, and then send it off to our partner as HTTPS traffic over port 443. The servers can’t do it, because the app can’t do it.
I read somewhere that SNAT plays a role in this last twist, but I can’t seem to find the forum post again. Is there a solution article out there that details how we can do this? Or has anyone done it, and can provide a blow-by-blow of what we need to do to make it work?
For the partner (HTTPS) → LTM → (HTTP) app traffic you can create a virtual server on port 443 with a client SSL profile pointing to a pool of the server(s) on port 4000. The replies will follow the reverse path. If your server(s) have their default gateway set to the LTM floating self IP, you don’t need SNAT. If that’s not the case, then use SNAT on the virtual server.
For the app (HTTP) → LTM → (HTTPS) partner traffic, you can create an HTTP virtual server with a server SSL profile pointing to a pool of the partner server(s) on port 443. You’ll need to use SNAT on this virtual server. You’ll also need a TMM route (or default route) to get to the partner network.
OK, so even if the servers are not responding to the partner’s packets, and the packets aren’t returning through an existing connection in BIG-IP, we still use a server ssl profile and it will automatically encrypt traffic that the LTM is seeing for the first time? I just want to make sure I’m understanding this correctly, because the LTM essentials course was stating that server ssl profiles were for “return” traffic - it didn’t say anything about fresh traffic that’s being initiated internally.
Replies are handled by the original virtual server the request went through. However, if you have both sets of hosts originating traffic, then you need two virtual servers.
For the VS which handles your requests to the partner, you use a server SSL profile to encrypt the LTM to partner pool traffic. For the VS which handles the partner requests to you, you use a client SSL profile to decrypt the requests and re-encrypt the responses on the clientside of LTM.
