Encrypt Cookie Name- Starts with BIGipServer
Hi All,
I am trying to encrypt cookie usign an irule. I am able to encrypt the cookie value but the cookie name exists.
The cookie i am refering is the BIG-IP cooke starts with
BIGipServer
. It says to the client about the pool name , iapp name etc which is looks good but not good for security.
Can we encrypt the cookie name as well?
-Jinshu
BIGipserver is the default name for a persistence cookie. You can change the name in the cookie persistence profile by customizing the “Cookie Name” field. The profile can also encrypt the cookie content.
If I change the cookie name to, for example, MyNewCookieName, will the name become static, or is it just change the prefix from BIGipServer[pool name] to MyNewCookieName[pool name]?
Rick,
The cookie name you configure replaces the entire default name including the pool.
