Hi everyone, I’ve been trying to get PFS enabled on my LTM (ver 11.4.1) and am running into a blocker. I’ve tried various cipher string options and have no luck so far. I’ve also opened a ticket with f5 support and they just point me to various devcentral discussions that don’t have the detail I need.
So I guess my question is: what are the cipher options I need to add/remove to enable PFS on a SSL client profile? or is there another way to get PFS going that I am missing?
i understand pfs is included since 11.2.1. you can display cipher suite list using tmm --clientciphers and tmm --serverciphers command.
Diffie-Hellman SSL key exchange cipher
The Diffie-Hellman SSL key exchange cipher, which provides perfect forward secrecy (PFS), is now included natively. This provides better performance for configurations using Diffie-Hellman, especially on physical platforms that have hardware SSL acceleration.
Yep that did the trick. So in order to enable PFS you have to explicitly disable all non-ECDHE ciphers. Bummer! And yes you are absolutely right it’s clientciphers not serverciphers, sorry for the mixup. Thanks for the help, it is much appreciated
I’ve just started having to look into this and this thread helped quite a bit. Sean by “explicitly disable” did you have to do something via command line or did you just specify the ECDHE ciphers in the SSL profile(s)?
By “Explicitly Disable”.. You go to Profile - SSL - Client and locate the parent Profile used such as clientssl. Go into that and click on Advanced configuration. Then in Ciphers, let’s say you want to enable ECDHE-RSA-AES128-CBC-SHA and disable AES128-SHA.. you would add following (notice that ! before each cipher makes it disabled) DEFAULT:!AES128-SHA:ECDHE-RSA-AES256-GCM-SHA384: Or you can do this in tmsh create /ltm profile client-ssl ciphers DEFAULT:!AES128-SHA:ECDHE-RSA-AES256-GCM-SHA384:
Thanks for the reply El Guapo. Didn’t see it until now. So I’ve started using the below cipher string in my client parent profile with also using the options field to disable SSLv2 and v3. ~~~ tmm --clientciphers ECDHE+HIGH:HIGH:@STRENGTH ID SUITE BITS PROT METHOD CIPHER MAC KEYX 0: 49172 ECDHE-RSA-AES256-CBC-SHA 256 TLS1 Native AES SHA ECDHE_RSA 1: 49172 ECDHE-RSA-AES256-CBC-SHA 256 TLS1.1 Native AES SHA ECDHE_RSA 2: 49172 ECDHE-RSA-AES256-CBC-SHA 256 TLS1.2 Native AES SHA ECDHE_RSA 3: 53 AES256-SHA 256 SSL3 Native AES SHA RSA 4: 53 AES256-SHA 256 TLS1 Native AES SHA RSA 5: 53 AES256-SHA 256 TLS1.1 Native AES SHA RSA 6: 53 AES256-SHA 256 TLS1.2 Native AES SHA RSA 7: 53 AES256-SHA 256 DTLS1 Native AES SHA RSA 8: 57 DHE-RSA-AES256-SHA 256 SSL3 Native AES SHA EDH/RSA 9: 57 DHE-RSA-AES256-SHA 256 TLS1 Native AES SHA EDH/RSA 10: 57 DHE-RSA-AES256-SHA 256 TLS1.1 Native AES SHA EDH/RSA 11: 57 DHE-RSA-AES256-SHA 256 TLS1.2 Native AES SHA EDH/RSA 12: 61 AES256-SHA256 256 TLS1.2 Native AES SHA256 RSA 13: 49170 ECDHE-RSA-DES-CBC3-SHA 192 TLS1 Native DES SHA ECDHE_RSA 14: 49170 ECDHE-RSA-DES-CBC3-SHA 192 TLS1.1 Native DES SHA ECDHE_RSA 15: 49170 ECDHE-RSA-DES-CBC3-SHA 192 TLS1.2 Native DES SHA ECDHE_RSA 16: 10 DES-CBC3-SHA 192 SSL3 Native DES SHA RSA 17: 10 DES-CBC3-SHA 192 TLS1 Native DES SHA RSA 18: 10 DES-CBC3-SHA 192 TLS1.1 Native DES SHA RSA 19: 10 DES-CBC3-SHA 192 TLS1.2 Native DES SHA RSA 20: 10 DES-CBC3-SHA 192 DTLS1 Native DES SHA RSA 21: 22 DHE-RSA-DES-CBC3-SHA 192 SSL3 Native DES SHA EDH/RSA 22: 22 DHE-RSA-DES-CBC3-SHA 192 TLS1 Native DES SHA EDH/RSA 23: 22 DHE-RSA-DES-CBC3-SHA 192 TLS1.1 Native DES SHA EDH/RSA 24: 22 DHE-RSA-DES-CBC3-SHA 192 TLS1.2 Native DES SHA EDH/RSA ~~~ The only thing I haven’t been able to resolve is the little warning in Chrome when you look at the cert information and it says that our site ‘is using obsolete cryptography’. I’m guessing there is a specific cipher(s) that is outdated in the list per my cipher options, but I’m not sure how to find which it is. Any guidance or places I should look to reference that?
>The only thing I haven’t been able to resolve is the little warning in Chrome when you look at the cert information and it says that our site ‘is using obsolete cryptography’. can you try to exclude sha1 (i.e. !SHA1)?
