Enabling or Disabling ASM / APM will interrupt traffic? F5’s are running version 12.1.2 HF2.
I’m not sure what you mean
- Enabling ASM in a virtual server won’t interrupt traffic, except if the policy is in blocking mode and some violations are detected.
- Disabling ASM in a virtual server won’t interrupt traffic.
- Enabling APM in a virtual server will force user to authenticate.
- Disabling APM in a virtual server will bypass SSO profile and can user to authenticate on the backend server.
- change module provisioning on active device will interrupt traffic because it restart services.
- change module provisioning on Standby device won’t interrupt traffic. provisioning is not synchronized between cluster members. you can then force failover to change provisioning on the other device.
