First I would run the following command to see what the configuration is.
list sys httpd
Next when you end the following I would use the question mark to see what configuration options are available to you. Sadly I do not have access to an F5 appliance with this code version so I cannot provide the specific command. Essentially you need to create the appropriate cipher suite command to do what you want and that changes a bit from version to version.
We have tried below commands but no luck as these commands are for 11.x and above .
To restrict Configuration utility access to clients using TLS 1.2 or RC4-SHA ciphers, type the following command:
modify /sys httpd ssl-ciphersuite ‘ALL:!ADH:!EXPORT:!eNULL:!MD5:!DES:RC4-SHA:!SSLv2:-TLSv1:-SSLv3:-TLSv1.1’
Alternatively, if you can restrict to only TLS 1.2 cipher, then type the following command instead:
modify /sys httpd ssl-ciphersuite ‘ALL:!ADH:!EXPORT:!eNULL:!MD5:!DES:!SSLv2:!SSLv3:!TLSv1:!TLSv1.1’
