I don’t want to enable ssl profile of server side in virtual server
but I want to enable ssl server side for some url ,such as /xyz
how to achieve this?
you have to assign serverssl profile to virtual server but disabling/enabling it in irule.
e.g.
[root@ve10:Active] config b virtual bar list
virtual bar {
snat automap
pool foo80
destination 172.28.19.252:443
ip protocol 6
rules qux
profiles {
clientssl {
clientside
http {}
serverssl {
serverside
tcp {}
[root@ve10:Active] config b pool foo80 list
pool foo80 {
members 200.200.200.101:80 {}
[root@ve10:Active] config b pool foo443 list
pool foo443 {
members 200.200.200.101:443 {}
[root@ve10:Active] config b rule qux list
rule qux {
SSL::disable serverside
if { [HTTP::uri] starts_with "/xyz" } {
SSL::enable serverside
pool foo443
[root@ve10:Active] config curl -Ik https://172.28.19.252/
HTTP/1.1 200 OK
Date: Tue, 16 Jul 2013 14:23:30 GMT
Server: Apache/2.2.3 (CentOS)
Last-Modified: Thu, 23 May 2013 00:28:46 GMT
ETag: "4185a8-59-c3efab80"
Accept-Ranges: bytes
Content-Length: 89
Connection: close
Content-Type: text/html; charset=UTF-8
[root@ve10:Active] config curl -Ik https://172.28.19.252/xyz/
HTTP/1.1 200 OK
Date: Tue, 16 Jul 2013 14:23:33 GMT
Last-Modified: Tue, 16 Jul 2013 14:22:22 GMT
ETag: "468841-59-b48d8380"
Content-Length: 89
Connection: close
actually I tried this one
when CLIENT_ACCEPTED {
if { [HTTP::uri] starts_with “/xyz” } {
pool foo443
will this work?what is the difference between this one and yours?
this is the vip config
virtual srwd33-www {
mirror enable
snat automap
destination 10.10.10.10:http
ip protocol tcp
rules test-irule
profiles {
http {}
oneconnect {}
serverssl {
serverside
tcp-lan-optimized {
serverside
tcp-wan-optimized {
clientside
irule test-irule before "it has intermittent issue which goes to fallback host if I want to hit default-pool
if { [HTTP::uri] starts_with “/test1” } {
pool xyz
return
else {
pool default-pool
test-irule after:it is fine
when SERVER_CONNECTED priority 10 {
if { [LB::server pool] eq “xyz” }{
else {
pool xyz
return
else {
pool default-pool
I want to know the root cause and which way is recommended
is it possible that there are multiple http requests in one tcp connection which some is https (xyz) and some is http (default-pool)?
hmmm,I am not sure
it is just non-keepalive connection for this vip
everytime I use one url to test,sometimes it works fine,sometimes it hit fallback host
in tcpdump ,I found F5 send encrypted data to default pool
