enable compression if parameter exists in content type
Newbie here. I’m trying to compress data with content type “text/html;charset=UTF-8”. I do not want to compress the data if the parameter is missing i.e content type “text/html” should not be compressed but “text/html;charset=UTF-8” should.
I’ve tried using the following rule but without success.
when HTTP_RESPONSE {
set content_type [string tolower [HTTP::header Content-Type]]
if { $content_type contains “text/html;charset=UTF-8”}{
COMPRESS::enable
change UTF in your if statement to utf since you are converting the content type information to lowercase.
Thanks for the responses…
The following rule worked.
if { [HTTP::header Content-Type] contains “charset”} {
COMPRESS::enable
Neither “text/html;charset=UTF-8” nor “charset=UTF-8” worked.
Are “;” and “=” considered as special characters that need to be escaped?
