EM discover devices
Problem this snippet solves:
Introduced: EM_v3.0
Use the discover_devices API to discover devices to be managed by an Enterprise Manager.
Important: If you plan to use iControl Proxy to communicate with discovered devices, you must discover them through the internal traffic interface; not the management interface.
How to use this snippet:
Prototype
Python
ic.Management.EM.discoverdevices(addresses = deviceaddresses, usernames = deviceusernames, passwords = devicepasswords)
C#, Java, and Perl
ic.ManagementEM.discover_devices(deviceAddresses, deviceUsernames, devicePasswords);
Inputs
Name Type Description
addresses String Sequence This parameter specifies the IP addresses or hostnames of the devices you want to discover.
usernames String Sequence This parameter specifies the username credentials of the devices you want to discover.
passwords String Sequence This parameter specifies the password credentials of the devices you want to discover.
Return Values
task String The ID of the new discovery task.
Exceptions
Exception Name This exception is raised when…
AccessDenied The credentials supplied by the client do not satisfy the F5 device’s validation requirements.
OperationFailed The API call causes an operation error.
InvalidArgument The API call contains an invalid argument.
Code :
To view a code sample, click the relevant code type.
<a href="#community-277347-" rel="nofollow noopener noreferrer">C# (.net)</a>
<a href="#community-277347-" rel="nofollow noopener noreferrer">Java</a>
<a href="#community-277347-" rel="nofollow noopener noreferrer">Perl</a>
<a href="#community-277347-" rel="nofollow noopener noreferrer">Python</a>
