What is the class header (class directive) that you need to use to add a Data Group (Class) to a EM changeset?
For example, this is what you need to add an iRule:
F5[Local Traffic / iRule]
rule myiRule {
Thanks in advance.
rule myiRule {
Thanks in advance.
A datagroup or class is defined in the bigip.conf like this:
class myClass {
Aaron
Thanks Aaron, I understand that. I am talking specifically about adding the Data Group member with an Enterprise Manager Changset. I need to know the class directive:
ie
F5[Local Traffic / Something Here]
Adding a node would look like this:
F5[Local Traffic / Node]
node 10.50.1.4 {
screen node1
Thanks,
Bob
I spoke with F5 support and adding class members is not supported with EM. Oh well…
