I have been working on the configuration of an EM 31.1.1 and when I try to make configuration deployments on the gueste I have the following error
Deploy: iControl error: ‘iControl::OperationFailed - primary code:1(0x1) secondary code: 0(0x0) string: Executing script with args [/var/tmp/merge.994TS9] , failed : can’t eval proc: “script::run” Loading configuration process failed. while executing “tmsh::load sys config merge file $file” (procedure “script::run” line 16) invoked from within “script::run” line:1’
The guest has the version 12.1.1 HF1 I have verified the contivity between the EM and the guest with the command curl -k -u admin: admin https: // and the command curl -k -u admin: admin -i https: // /iControl/iControlPortal.cgi and is successful; Make a capture on the guet and the result is the following; Depronto alguine can give me a hand … to understand the problem …
