else procedure undefined?
i have what I think is a simple iRule (i am a complete novice mind you). i can not get the else command to work. gives the following eror no matter what i do. sorry if i am just dense
01070151:3: Rule [iRule1] error:
line 32: [undefined procedure: else] [else]
_______________________________________________________________________
iRule:
switch -glob [string tolower [HTTP::uri]] {
“/affiliates” -
“/endpages” -
“/friends” -
“/images” -
“/img” -
“/inc” -
“/includes” -
“/maintenance” -
“/outage” -
“/popup” -
“/referral” -
“/sc” -
“/servicestudy” -
“/sitemap” -
“/thrivent” -
“/upgrade” -
“/userControls” {
pool Pool1
else
{HTTP::redirect “http://blahblah.com”}
In most tcl implementations both braces need to be on the same line with the “else”, since the “else” is actually part of the “if” command.
In F5’s tcl implementation, the “else” has to be on the same line as the leading brace, but the trailing brace may be on the next line.
Standard tcl syntax:
if { condition }{
  code
  code
Alternate F5 syntax:
if { condition }{
  code
} else
  code
And unless your URIs consist only of the specified directories with no trailing path or filename, you will also need to wildcard your switch patterns to get the expected matches:
    "/affiliates*" -
    "/endpages*" -
    "/friends*" -
HTH
/deb
(edited previous post for typos in code example - doh!)
If what you were trying to do with the else is to provide a “default” clause for the switch statement (ie. everything that doesn’t match one of your previous comparisons), then you can make use of the built-in “default” keyword in the switch statement. “else” is part of the “if” clause, not switch.
Oh, and Deb is right that you’ll probably want wildcards if you want your comparison to be like the “starts_with” operator.
    "/affiliates*" -
    "/endpages*" -
    "/friends*" -
    "/images*" -
    "/img*" -
    "/inc*" -
    "/includes*" -
    "/maintenance*" -
    "/outage*" -
    "/popup*" -
    "/referral*" -
    "/sc*" -
    "/servicestudy*" -
    "/sitemap*" -
    "/thrivent*" -
    "/upgrade*" -
    "/userControls*" {
      pool Pool1
    default {
      HTTP::redirect "http://blahblah.com"
-Joe
