Problem this snippet solves:
Deterministically load balances and persists connections to a server using an election hash in lieu of maintaining a large persistence table in memory. Very efficient solution for load balancing high-volume caches & proxies where low overhead stickiness to the same server is desirable for matching requests. The election hash solution overcomes the shortcomings of typical hash algorithms which can disintegrate when pool membership is in flux. Be sure to read Nathan’s comprehensive description of the problem and his simple and elegant solution here: DevCentral
How to use this snippet:
Note: These iRules require LTM version 9.4.2 or better.
Code :
# iRule Source: Basic Election Hash iRule
# Election Hash iRule
# Compute Hash - MD5
# Version 3.0 Dec 4th 2007
# MD5 calculation of Server + URI
# Rule selects Server that scores highest
# S = Current high score
# N = Node being evaluated
# W = Winning node
# Change "myPool" to your pool name.
set S ""
foreach N [active_members -list myPool] {
if { [md5 $N[HTTP::uri]] > $S } {
set S [md5 $N[HTTP::uri]]
set W $N
pool myPool member [lindex $W 0] [lindex $W 1]
# LTM sample log results with four nodes active in the pool:
Rule: Node: 172.29.4.53/32 Score: 917
Rule: Node: 172.29.4.54/32 Score: 67
Rule: Node: 172.29.4.55/32 Score: 74
Rule: Node: 172.29.4.56/32 Score: 577
Rule: Picked Node: 172.29.4.53 URI: /images/logo.gif Highest Score: 917
# The results when node .53 is unavailable:
Rule: Picked Node: 172.29.4.56 URI: /images/logo.gif Highest Score: 577
# The iRule correctly scored each possible node against the object requested and selected the highest scoring server. Removing a node only affected traffic which that node had previously won.
# iRule Source: Compound Election Hash iRule
# Compound Compute Hash - MD5
# Basic hash picks a pool containing
# a subset of servers. Then perform
# election hash across pool members.
# Pools must be named Pool_<0-n>.
# Change % 10 to highest numbered pool.
# W = Winning node
# P = Pool name
when HTTP_REQUEST timing on {
set S ""
binary scan [md5 [HTTP::uri]] i1 P
set P Pool_[expr $P % 10]
foreach N [active_members -list $P] {
set W $N
pool $P member [lindex $W 0] [lindex $W 1]
# Note: For compatibility prior to v9.4.2 the following was created
# Version 3.1 September 25th 2009
# W = Winning node
# Replace IPADDR1, IPPADDR2, IPADDRN with the node IPs contained in "myPool"
# Replace <port> with the port number of the nodes contained within "myPool"
set GOOD_NODES {}
set NS {IPADDR1 IPADDR2 IPADDRN }
set portnum <port>
set S ""
# This looks through myPool nodes to determine the one's that are active
# and passes it onto the array called GOOD_NODES
foreach N $NS {
if { [LB::status pool myPool $N $portnum] eq "up" } {
lappend GOOD_NODES $N
foreach N $GOOD_NODES {
set W $N
}</port></port>
Tested this on version:
9.4
