Edit LTM configuration from CLI
Hi Experts,
I have a config like this.
user@(LTM)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm node Server
ltm node Server {
    **address 10.10.24.17**
    partition Common
    session monitor-enabled
    state up
How do I change the node IP address from 10.10.24.17 to something else? I tried the ‘modify ltm node’ command, but it didn’t give an option to change the IP address?
You’ll not be able to IP address. You can add another node and delete this one. You can modify certain properties of node but not IP address. Alternatively you can edit config and reload & resysnc.
