edit a request variable after being set?
I’m setting a variable copy of a GET request, is it possible to change the values within the variable after I have set? for instance, the URI?
example:
set req [HTTP::request]
set req uri = "new/uri"
Thanks Jon
HTTP::uri [HTTP::uri]/new/uri
Something like the above in the iRule will append “/new/uri” to the existing URI. Is that what you are seeking ? Basically, with the [ ] brackets, you are reading the variable and without the [ ] brackets, you are writing to it.
Added as answer so i can format
Here is the irule, i have *** where the functionality needs to go.
    set Original_request [HTTP::request]
    HTTP::uri "/newURI[HTTP::uri]"
     Send the out-of-band validation query to the MicroService.
        log local0. "Calling new service"
    pool new_service_pool
when HTTP_RESPONSE {
    if {[HTTP::status] eq 302 } {
    pool 2nd_pool
    ***** Change the $Original_request URI ****
    HTTP::retry $Original_request
      log local0. "No Re-direct - Carry on as we were"
Instead of saving the request, why not use a fresh one ? The fresh one seems to be completely independent of the saved request, unless I am mistaken.
Hi, I need the original request parameters, however I have used String manipulation for this now. Thanks for your help. JT
