I am struggling to find detailed information about what exactly the F5 Edge Client is doing on remote client’s PC when client-side checks, for example ‘firewall check’ is configured and run by the APM policy.
The firewall check is as simple as ‘Windows Firewall of any version must be turned on’.
From time to time, we experience problems with some users who suddenly cannot use remote access because the ‘firewall check’ is suddenly failing, although their Windows Firewall is turned on. (and they had no issues before).
I don’t believe it is a problem of the actual windows firewall. I assume that something must have been changed on the client’s PC which somehow prevents the Edge Client to perform this client-side check. All I was able to find in F5 documentation is that these client-side checks use ActiveX to perform their checks.
Do you know what exactly must be allowed / turned on / configured on the client PC in order to successfully run these client-side checks? What (process, service, files?) and how (activeX, plugins?) is the Edge Client executing its checks? Can I maybe find some error message in Edge Client logs helping to understand this behavior somewhere? Because the APM’s logs are not useful.
Thanks, Martin
