Trying to create an ECV for Azure Rights management server.
https://rms.abc.com/_wmcs/certification/certification.asmx
Expected reply: CertificationWebService
Username & password are provided by application owner.
Configured below on https health monitor
Send string: GET/_wmcs/certification/certification.asmx HTTP/1.1\r\nHost:rms.abc.com Receive String: CertificationWebService
Username: testusr@abc.com Password: *******
The pool members are marked down.
doing a curl -k gives below error
HTTP Error 401.2 - Unauthorized You are not authorized to view this page due to invalid authentication headers.
Most likely causes:
- No authentication protocol (including anonymous) is selected in IIS.
- Only integrated authentication is enabled, and a client browser was used that does not support integrated authentication.
- Integrated authentication is enabled and the request was sent through a proxy that changed the authentication headers before they reach the Web server.
- The Web server is not configured for anonymous access and a required authorization header was not received.
- The “configuration/system.webServer/authorization” configuration section may be explicitly denying the user access.
Things you can try:
- Verify the authentication setting for the resource and then try requesting the resource using that authentication method.
- Verify that the client browser supports Integrated authentication.
- Verify that the request is not going through a proxy when Integrated authentication is used.
- Verify that the user is not explicitly denied access in the “configuration/system.webServer/authorization” configuration section.
- Create a tracing rule to track failed requests for this HTTP status code. For more information about creating a tracing rule for failed requests, click here.
Detailed Error Information:
Module IIS Web Core
Notification AuthenticateRequest
Handler WebServiceHandlerFactory-ISAPI-4.0-64
Error Code 0x80070005
