What’s the best way to swap X and Y pool members with A and B, assuming hundreds of affected pools and variable port numbers?
Can tmsh do this or is editing the bigip.conf file the best way to go?
I would probably do this using a script with a loop to run tmsh commands against pools.
something like:
$pools = “pool1 pool2 pool3”
$a = 5.5.5.5:80
$b = 6.6.6.6:80
$x = 1.1.1.1:80
$y = 1.1.1.2:80
for poolname in $pools; do
tmsh modify ltm pool $poolName members add { $x $y};
tmsh modify ltm pool $poolName members delete { $a $b};
done
