EAC Restrict Access does not work for Exchange 2016 via iApp
URL: */ecp/?ExchClientVer=15
does not match
URI Check: /ecp/default.aspx
My testing shows that this allows external access for Admins.
Of course they don’t match. What is this about and what are you trying to achieve? Some more info would help.
Disable external access to the ECP for Admins who are members of the Exchange Organization Management Security Group?
as per ms “organizations may want to restrict access to the EAC for client connections from the Internet”
Should BIG-IP APM restrict EAC access to members of the Exchange Organization Management Security Group? Yes, restrict EAC access by group membership
seems to me this is around the wrong way around and doesn’t match anyway. or am i missing something?
So in theory this is meant to block ecp to users who might change personal details, members of groups they own or wipe their own phone which got stolen. Where as we allow admins full access to change smtp routing, any policy they want, disable access to all other admins…
OK, as I understand it from the link above, MS recommends that access to “/ecp” be restricted to from the internal network by way of disabling the service but setting it up on a different IP address for access from the internal network only.
Now, in what way has this to do with F5 in your deployment?
So in theory this is meant to block ecp to users who might change personal details, members of groups they own or wipe their own phone which got stolen. Where as we allow admins full access to change smtp routing, any policy they want, disable access to all other admins… What I can’t understand is when and why would I want to do that?
Surely it would make more sense to block ECP access to Admins via the the APM and iapp and allow normal users access.
I see. Our deployment here is to allow all through (per business request). So I don’t see the bit about APM’s group membership checking in our configurations.
Going through the code of the iapp myself though, I can see that “/ecp/default.aspx” is the landing page. I can’t find a string match of “ExchClientVer” anywhere.
I also see this:
"Because you are deploying the BIG-IP APM, you can restrict Exchange Administration Center (EAC) access to members of Exchange 2013's Organizational Management group. The BIG-IP APM module queries Active Directory group membership and the BIG-IP APM policy allows or denies access based on membership."
Anyway, there seems to be 2 things here: 1) The APM acl function does not work (not matching a certain string); and 2) it seems pointless to have this function from your perspective.
So what do we want to do?
That’s the one :slight_smile:
I’ve changed the EAC URI branch rules and added “OR Landing URI is /ecp/?ExchClientVer=15” and changed the successful “Allow” to a Deny
Users won’t hit the ?ExchClientVer=15 appears they only use the /ecp/ URI
no luck with that config
Will you share the text of that rule?
It seems to me the “EAC URI” should check “/ecp/default.aspx” only, and if AD query (of security group membership I presume) is successful the access should be allowed, instead of denied, which should be the case of the fallback.
And you might want to enable traceing to see what is really going on. See K13384: Performing a web applications trace (11.x - 12.x).
Added a new irule, I was hoping to display this page after the user is authenticated via the apm. Any thought’s?
Thanks in advance. Josh
priority 899
        switch -glob -- [string tolower [HTTP::path]] {
        "/ecp*" {
             Respond with a splash page with redirection.
            HTTP::respond 200 content {
                    External ECP Access Disabled
                    External Exchange Control Pannel (ECP)
                    We are sorry, for security reasons external ECP access is disabled.
                    To return click
priority 899
     Bar admin access:
    if { [HTTP::uri] starts_with "/ecp/?ExchClientVer=15" } {
        HTTP::respond 403 content {
                  To return click
        } "Content-Type" "text/html" Connection close
[Edited]
Hi Guys,
Any comments on the EAC function of the iapp? as per the below 2 points. Are we looking at updating the deployment guide and iapp at some point or are we missing something?
"Anyway, there seems to be 2 things here: 1) The APM acl function does not work (not matching a certain string); and 2) it seems pointless to have this function from your perspective."
priority 899
     Bar admin access:
    if { [string tolower [HTTP::uri]] starts_with "/ecp/?exch" } {
     Bar access from everybody:
    if { [HTTP::uri] starts_with "/ecp" } {
                  To return click
Well, you may well add the “string tolower” bit, but I should think such a URL ought to be case-sensitive. I never tested it though.
Thanks for the reply. From our testing, it showed that if you used “ecp/?exchclientver=15” or “ECP/?ExchClientVer=15” the irule would not match and grant users access.
Once all our mailboxes have been migrated to exchange 2016 we will bar all external users to the ecp directory
