Hi Everybody.
Is there any changes on XML features on 9.3.1 HF2?
All XML samples from devcentral are getting error. Notice that XML_BEGIN_DOCUMENT, XML::subscribe and XML::collect shows no error.
when XML_BEGIN_DOCUMENT {
XML::subscribe allevent
XML::collect
when XML_BEGIN_ELEMENT {
log local0. "Found Element [XML::element]"
And I’m getting the following error:
line 6: [wrong args] [XML::element]
Thanks!
hi,
it looks like you need an Early access license to do xml manipulation: Click here
Do you have it ?
Hi nmenant.
I have the EA license. F5 staff sent me the license.
Does it come identified as “EA Features” under license file?
Here is my bigip license.
ADD LTM MODULE
Add Compression (X 1 MBPS)
ADD SSL TPS
ADD 5 MBPS COMPRESSION
ADD RAMCACHE
ADD RATE SHAPING
ADD ROUTING BUNDLE
ADD SSL 100
EA Features
Thanks for your help!
Yes you have the license for early access so it should be working Oo
