Dynamic routing in f5
Hi All/DC Experts,
Does f5 supports dynamic routing?
Everytime I configured network address and I will use default GW f5 doesn’t accept my config.
But when I make it static with 255.255.255.255 subnet mask f5 accepts it.
-Nat
You mention dynamic routing (ospf, bgp, rip), but then you talk about a problem configuring a default gateway - are you asking about dynamic routing to avoid that problem ? Can you give us some more information about the error - what is the actual message you get ?
Ian Hi,
Just want to know if dynamic routing is supported by f5.
Kindly disregard the configuration I’ve mention.
THanks
-Nat
