Duplicating TCP messages and suppressing response
I have a couple of proprietary telecom nodes that I would like to load balance across, but problem is that client has to go through an initial registration process with a server before it will take client transactions. All of this happens with TCP and there is NO encryption or SSL.
I don’t know if this is possible, but I am wondering if something like this is possible…
(Assuming I have LTM between client and two server nodes)
When client sends initial registration request to LTM VIP, I need to:
1) duplicate the message (send the client message to server-1 and server-2 at the same time)
2) have the LTM respond properly to both servers for any TCP message from both servers
3) suppress the duplicate response messages from server-2 (don’t send them to the client, but respond properly to server)
4) make sure the client only gets response from server-1
Assuming this works for the initial registration process with each server, I think I could start sending transactions to the LTM that would be load balanced across both server nodes, because each transaction is handled inside of a single TCP connection.
Any ideas or any other ways to do this would be appreciated!!!
Thanks!
If it were HTTP traffic, you might be able to begin with one server, then use HTTP::retry (Click here) to replay the registration transaction with the 2nd server, then stick with it for the life of that HTTP connection and load balance follow-on connections. (More than 2 would considerably complexify the logic.)
There is no equivalent retry command for TCP traffic, though…
/deb
