Duplicate Unit IDs
Hello,
I hve a redundant pair that currently has 2 boxes with the same Unit ID. Will this affect the syncingcapability or any little errors? We do notice that the standby box always shows its monitors going down in he logs.
Any ideas or direction?
Thank you
The unit ID is only used in an active - active pair for setting which unit should own which objects. I don’t think it would have anything to do with monitoring failures. If you’re using an active - standby configuration the unit ID shouldn’t have any impact on anything.
Here is a page with some tips on troubleshooting monitor failures:
http://devcentral.f5.com/Wiki/default.aspx/AdvDesignConfig/TroubleshootingLtmMonitors.html
Aaron
Thanks for the Quick response Aaron. I will look at the link also
Also is it possible to change the hostname of a server without rebuilding it?
Sure. It’s changed in 9.4.2 so there are two methods.
Aaron
From SOL4802:
For BIG-IP versions 9.4.2 and later:
bigpipe system hostname
Replace with the fully qualified hostname for the BIG-IP system.
For example:
bigpipe system hostname askbig9n1.askf5.com
For BIG-IP versions 9.0 through 9.4.1:
bigpipe db HostName
For example:
bigpipe db HostName askbig9n1.askf5.com
