b profile http test_ramcache ramcache max 1000 dump
what is the equivalent command for the above in version 9.46
Thanks,
Thanks,
Thanks.
I tried to search thru the cli guide but didnt find anything that would be similar to the dump command in version prior to 946.
b profile http test_ramcache ramcache entry all is suppose to list all entries however I dont think it does. I think it only lists the top 10? (or last 10).
any thoughts?
thanks,
It does seem to limit the output to ten files. I couldn’t figure out a way to list all the cached files. I’m pretty sure the full list was given in 9.4.5.
Maybe someone else has a suggestion? Else, you could open a case with F5 Support.
Aaron
