I’m preparing a migration and have a question about DSC support for a mixed hardware scenario:
2 VIPRION chassis
each chassis has a single B2100 blade
each blade has 3 vCMP guests
DSC sync-failover is configured between vCMP guests hosted in those blades
each blade will be replaced by a B2250, but the configurations won’t change
I’d like to do this without downtime, but there is a crucial step, when one of the blades has already changed to a B2250 and the other is still a B2100: will vCMP guests based on different hardware be able to join in a DSC sync-failover group?
Starting in BIG-IP 11.4.0, the BIG-IP system supports high availability (HA) features, such as ConfigSync and failover, between different hardware platforms.
normally i would point out to size against the less powerful system. but i believe you wont run like this for long.
