I am trying to emulate the ability in Apache to accept or drop traffic to a particular vhost based on IP. So for instance, my Apache’s vhost config says:
Order deny,allow
Deny from All
Allow from 192.168.30.0/24
Allow from 192.168.15.0/24
Allow from 10.1.20.0/24
However the 10 network comes from my LTM, so any host hitting the virtual IP would show to Apache as a good IP. What I have tried is create an address type datagroup called localnets which includes:
However this fails with errors all over. My guess is that I am trying to do a layer 7 and layer 3 check in the same rule and this is not allowed. I have seen the examples on here that either work on ONLY source IP or ONLY HTTP host, but not a combination. Where do I start?
That worked. Excellent. now I am stuck on part two of this.
I only want this iRule to apply to requests with that host there fore I added an extra else if
if { ([HTTP::host] matches “myapp.somehost.com”) and [class match [IP::client_addr] equals localnets]} {
pool /Common/pool_ruby_http
} elseif { ([HTTP::host] matches “myapp.somehost.com”) and [class match [IP::client_addr] equals not localnets]} {
discard
I can find all sorts of documentation on how to make positive logic, but not negative… thus I am just guessing on combinations of ‘not equals’, !equals etc and seeming to not get anywhere.
EDIT: I think I got it
} elseif { ([HTTP::host] matches “myapp.somehost.com”) and not [class match [IP::client_addr] equals localnets]} {
Another thing to consider is requests with a host header that isn’t myapp.somehost.com. It would be trivial for a user to set whatever host header they want with a hosts file entry pointing to the public IP address of your virtual server. Or they could just use the IP address. In that case, the requests wouldn’t match your iRule logic and would go to the virtual server’s default pool if one is defined.
To address this, you could either not check the host header or not have a default pool on the virtual server.
