DR I-rule
Hi
is it possible to create a i-rule that stats
use pool1 - if pool1 can’t be reached for 10 minutes - route to pool2
I wonder if Priority Group Activation would be a better method with the Pool2 members having a lower priority than the Pool1 members and the Pool Monitor timers adjusted accordingly?
That would work the only problem is there has to be two pools cause my security department will not approve otherwise…
Can you set time limits on a irule…
