Downgrading from 12.1.2 to 11.6.1
Hi, I’m doing a downgrade from 12.1.2 to 11.6.1 :
1) Once I boot from a particular volume which has 11.6.1 will the configuration also load ? or should I import from the UCS file ?
2) Should the license be rea-ctiviated again from 12 to 11 ?
HI
check it (the way is the same)
Downgrading BIG-IP software (10.x - 11.x)
do you have v11.6 ucs file ? you must only use
Downgrading version ucs.
can be restore.
if your no have. only use scf output to install Downgrading version .
Overview of single configuration files (11.x - 12.x)
and backup output v12 certificate file to import Downgrading version.
or use
platform-migrate option
2) License must re-activiated again!
Have a good day!
Thanks a lot :slight_smile:
Do you know if the SCF file also contain Zebos configuration if we are using the dynamic routing protocols ?
Amos
HI slick
I guess zebos config file is not in scf file.
K13408: Overview of single configuration files (11.x - 12.x)
if you want to use dynamic routing protocols.
  1. you need Advanced Routing Modules license
  2. config Advanced Routing Modules Dynamic Routing
and backup Zebos.conf to restore new f5 downgrade version partition
have a good day!
Thanks for the quick reply. We use dynamic routing extensively, so excluding this from SCF is a pain for us.
Another, more important question, the SCF overview document you pointed us has the following comment: You can only install the SCF to a BIG-IP running the same or newer version than the version the SCF was created on.
Did you get a chance to test this ? The comment on the documentation says it worn’t work, although I don’t see why if I’m not suing 12.1 specific features.
HI slick
i can try it. but it will in tomorrow!
but i don’t know the config will be you want.
have a good day!
