downgrade from Kernel 9.4.3 to 9.3.0
Hi all,
I am trying to downgrade de kernel but with no results, could i have some help please.
I have tried local im /var/tmp/local-install-9.3.0.178.5.im it aborts at the midle of the process. and directly usind a mounted image!
the result is the same
machine BIG-IP 1500
regards,
DevCentral is setup to assist with development related issues. We aren’t staffed to support product related issues. If you are having problems imaging your system, you will get better results by contacting our product technical support department.
-Joe
no problem, thankx!
