I may have found the solution here:
Formatting the file system and installing a base BIG-IP version (10.0.x - 10.2.0)
BIG-IP version 10.2.1 onwards
image2disk --nosaveconfig --format=volumes
For example, the ISO image name is BIGIP-10.2.1.297.0.iso, you would use the following syntax:
image2disk --nosaveconfig --format=volumes /shared/images/BIGIP-10.2.1.297.0.iso
The current status of the volumes on the unit is:
bigpipe software volumes show
SOFTWARE - Volumes:
±> SOFTWARE VOLUME HD1.1 Size: default active
±> SOFTWARE VOLUME HD1.2 Size: default inactive
±> SOFTWARE VOLUME HD1.3 Size: default inactive
If that works, I’m guessing the next step would be to:
* perform an lvscan and expect no output
* fix the console if it falls over
* scp local-install-9.4.7.320.1.im to /var/tmp/ on the unit
* im local-install-9.4.7.320.1.im
* manually re-license the unit
* configure host name, time zone, etc
Has anybody tested that ‘image2disk --nosaveconfig --format=volumes /shared/images/BIGIP-10.2.1.297.0.iso’ command?
