Doing mTLS Authentication per URL
A customer asked if F5 supports mTLS Authentication per URL because some firewall vendors do not support this use case. At first, I thought it seems not possible because mTLS works at the lower OSI level before the URL is seen at OSI L7. A college suggested that it should be possible to decrypt the TLS, check the URL and then do the mTLS authentication when needed. Apparently, there are couple of simple iRules we can use to fulfill the requirement which is to do mTLS authentication based on certain URL.
Here is a simple iRules in need based on https://clouddocs.f5.com/api/irules/SSL__cert.html :
  if { [HTTP::path] eq "/sensitive_url" } {
    if { [SSL::cert count] > 0 } {
      if { [SSL::verify_result ] == 0 } {
        # Good mTLS result, exit from this check
        return
        set error_string [X509::verify_cert_error_string [SSL::verify_result]]
      set error_string "No client certificate provided"
    # If we are still executing this iRule, the client did not present a cert or did not present a valid cert
    HTTP::respond 403 content "<html>Invalid client certificate: $error_string</html>"
We have to expect that the client might come without the TLS certificate when accessing non-sensitive URL. To accomodate this condition, we have to adjust the Client-SSL profile attached to the VS to allow clients without client SSL certificate. We can select the “request” option on Client Certificate of the Client Authentication section inside the Client SSL profile.
That is all needed to fulfill the requirement of mTLS Authentication per URL. You can adjust the iRules to check the URL against a datagroup if there are multiple URLs to be authenticated. You also might want to reduce the error message to minimum in order to avoid attackers interpreting their mistake by not giving the right client SSL certificate.
Let me know your thoughts by leaving your comments below.
Wow, that’s it? That simple?
Yes,  @DavisLi . It is that simple 😉
Great Article ! Kudos ! Saved our life
Is it possible to remove client certificate request for non-sensitive URL?
Hi  @jhosseini  ,
The non-sensitive URL is identified after the mTLS handshake is completed. As mentioned in the article, mTLS is processed before the HTTP layer. It is not possible to remove the client certificate request during mTLS handshake when the client even has not sent the HTTP request containing the URI.
The above solution still allows clients who establish mTLS connections without client certificate and request for non-sensitive URL. This is because the VS’ ClientSSL profile is configured with “request” flag and the client is free to ignore the request. The VS will still allow clients coming in without client certificate.
Hi - i have similar scenario - for a specific URL the client browser is prompted for certificate . and that certificate is passed as header for authentication .
clients are using Windows OS - and they have a company certificate installed on their machine .
Question - is there a way to present the certificate with prompting to select certificate?
thanks
Hi  @awan_m ,
I don’t know how to trigger the client browser to prompt for the client certificate.
Cheers.
First add a client SSL profile with client authentication none; but, CA bundle added.
Trick is to add few lines  in HTTP_REQUEST in the iRule if uri matches certain pattern that will change authenticatio mode to required and SSL connection will be forced to renogotiate
Checkout few helpful articles:
https://community.f5.com/t5/technical-articles/selective-client-cert-authentication/ta-p/275555
https://community.f5.com/t5/technical-forum/client-authentication-with-certificate-on-one-uri-only/m-p/303435#M262827
Hope these help
Also, this is simple and sufficient
https://community.f5.com/t5/technical-forum/client-authentication-based-on-uri/td-p/110650
