in previous versions I was told that you could not apply ASM and WA to a virtual server because they were implemented via a HTTP Profile and each Virtual Server could only have one HTTP Profile. Has this cahnged?
Thanks,
Carlb
Thanks,
Carlb
If you have a 6900/8900 platform, you can run ASM/WA concurrently in version 10. The specifics are the version 10 ASM release notes:
