Can anyone tell me if the F5 Edge Client supports PPPoE? Documentation states F5 BIG-IP supports PPPoE though I was not sure if this is specific to network tunnels or also includes client VPN.
The Edge Client has very little configuration, so the question is more if the APM supports VPNs with PPPoE.
This is first time a see a question about PPPoE and APM. As far as I know, the only protocol that is used for the VPN is SSL.
However, based on this ID:
ā445399Support was added for Network Access over PPPoE.ā
We can conclude that there was a limitation when using the SSL VPN on top of a PPPoE connection. Like if you have a ADSL modem, and connect to the Internet from your PC using PPPoE connection, and do the APM SSL VPN after.
